cosmetic brake question
Who the hell cares?
They are brakes not a display at the Smithsonian.
EDIT:Out of sight out of mind. http://www.roverparts.com/Parts/3044.cfm
Who the hell cares?
EDIT:Out of sight out of mind. Wheel Dust Shield - 16" (3044 Same Fit As Part # 1676) - Land Rover wheel accessories from Atlantic British
The reason they stick is because they are dissimilar metals, alloy rims and steel, the constant heating/cooling of the two metals causes them to "become one", any kind of barrier between them will prevent this from happening.
Same if you used steel rims, wont happen.
If you dont want your calipers to seize up then dont drive it anywhere.
The part of the caliper you are worried about has zero to do with a caliper seizing up.
There is nothing wrong with painting the calipers and what not, but keep in mind if it was a real issue they would come that way from the factory.
brandonjayjones
09-25-2012 08:29 AM
