Could coolant cause overheating?
Old Apr 3, 2011 | 06:19 PM
primo's Avatar
8th Gear
Default Could coolant cause overheating?
I used to put water in my DII and then I put in this Prestone Extended Life Coolant (Advance Auto Parts: Extended Life Antifreeze/Coolant (1 Gallon) by Prestone - Part AF2000)
About a week later it starts overheating without leaks or anything. Could this be caused by this coolant somehow?!
Old Apr 3, 2011 | 07:33 PM
Very doubtful that the coolant caused this issue.
Running just straight water will ruin your water pump bearings and cause scale and lime buildup inside your cooling system.
Old Apr 3, 2011 | 07:36 PM
antichrist's Avatar
Did you cut it 50/50 with distilled water, or use it full strength? If the latter then yeah.
Old Apr 3, 2011 | 08:10 PM
thospb's Avatar
Pure Anti-freeze cannot release heat, which is why it should be diluted 50% with distilled water. In hot climates it is often diluted 60% to improve cooling. If you use mineral water (Tap water) you risk electrolisys which may damage components and even create leaks. So the short answer is "yes" if you ran pure anti-freeze it can cause over heating.
Old Apr 3, 2011 | 09:00 PM
primo's Avatar
8th Gear
Ok, so what do I have to do to stop the overheating and stop it from happening again?
Old Apr 3, 2011 | 09:04 PM
You need to drain the system and fill with a 50/50 mix of coolant.
If you buy it premixed you wont have to worry about the mixture because it will be correct.
You will need 2 gals of premixed 50/50 engine coolant.
Old Apr 3, 2011 | 09:11 PM
SDinDS's Avatar
And throw in a bottle of Water Wetter or Purple Ice
Eric
Phatrowles
Jan 9, 2014 10:36 AM
Alyssa Bauman
Dec 16, 2013 08:49 AM
Rabih A. Yaghi
Jun 21, 2013 09:33 AM
0304Disco
May 19, 2011 03:18 PM
Vertigo RT
Sep 6, 2010 11:44 AM
