could this be true?
Old Dec 10, 2015 | 03:27 PM
lrguy46's Avatar
Hi
You learn something new every day! I had always used a compression tester that gave a pretty good indication when readings were compared cylinder to cylinder but I can see that, with proper equipment, this test could be meaningful as well but relied on valves being closed and the crankshaft not rotating.
I will chat with the service place when I collect the car tonight and will try to clarify some of the statements he made that flagged warnings in my head.
Old Dec 10, 2015 | 03:35 PM
Charlie_V's Avatar
I took my valve covers apart recently and cleaned them and, like a previous poster, I don't see how you could get a scope to the rockers because of a shield (which I took off and cleaned, and replaced).
I would take the four bolts off and look at the rockers yourself. Take 10 minutes. If they are dry, then the passages are blocked or the oil pump isn't doing its job; but if the latter, I think you'd have bigger problems and you would have heard scraping and crunching when you turn it over.
Old Dec 10, 2015 | 04:30 PM
dgi 07's Avatar
Originally Posted by lrguy46
Hi
Our factory tester does a compression test at the push of a button. we use smoke to narrow down what was leaking. Pump smoke into the cylinder with all valves closed. If it comes out the intake, you have intake valves leaking. If it comes out the exhaust, exhaust valves are leaking. If it comes out the next cylinder. head-gasket or cracked head. Comes out the oil cap, worn rings.
One case was a cracked head. the other was scoring on the cylinder walls wasn't giving the rings a good seal. That car got a new engine.
Old Dec 10, 2015 | 05:25 PM
lrguy46's Avatar
Hi
The scoring issue interested me.
Decades ago in the uk, if this was an issue I would have the cylinders rebored and oversize Hepolite Pep pistons fitted that had extra rings including an oil control ring near the base of the piston .
That was an alternative to a new engine.
Correction due to memory playing tricks.... I have had engines rebored but just use standard oversize pistons.
The Hepolite Pep pistons was a trick my father showed me... they were designed to bring new life into old worn out engines. They had a stepped rim dodger top compression seal ring along with additional compression and scraper rings below and the extra oil control ring at the base of the piston.
This link rather shows my age....http://www.oldclassiccar.co.uk/hepolite.htm
Old Dec 10, 2015 | 05:37 PM
dgi 07's Avatar
Warranty runs differently. In addition Mercedes engines have some type of liner that we dont have the equipment to replace. They are they only ones that can, as far as I know. No one really knows how the liners are attached either. And all our engines get sent back to German for some reason.
Camdisco24
Apr 22, 2007 12:37 PM
mr.47
Dec 14, 2006 11:06 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
surf9ska
Feb 14, 2006 03:52 PM
