CounterAct Corrosion Protection
Old Oct 11, 2008 | 01:18 AM
99LRDisc's Avatar
Default CounterAct Corrosion Protection
Seen it on speed TV. read it on the internet. Did much reaserch of it. They have Five models. The 5th is for Land Rovers alone.
"modified version of our proven OR-4 design modified to specifically address the corrosion problems of aluminum body-steel frame vehicles, especially suited to addressing galvanic cell corrosion at frame/body junctions of the Land Rover"
Any opinions. You can search it on google easily if your curious as well.
Old Oct 11, 2008 | 10:47 AM
Default RE: CounterAct Corrosion Protection
Never saw it.
Old Oct 11, 2008 | 11:01 AM
jkid's Avatar
I had a unit similar to this one my explorer about ten years ago (don't know who made it). That truck was really rusty and the unit had tons of rust around where it was mounted, I don't believe it did anything.
I didn't read the whole website, but they seem to usea lot of big, technical sounding words and phrases yet don't really tell you a whole lot about the product.
Old Oct 13, 2008 | 08:27 PM
shark19's Avatar
I have a corrosion protection system. It is called a leaking front seal. Whole bottom of truck is coated with oil.
Old Oct 13, 2008 | 10:33 PM
Switzer's Avatar
ORIGINAL: shark19
Old Oct 14, 2008 | 01:31 AM
WolfPack's Avatar
This would work by you already having the rust gone. So all the same prep work just like you were going to undercoat it. Then you hook this up, and the idea would be it actually prevents the metal from oxidizing and rusting. The electric charge the unit gives the metal keeps the ions off that would rust the metal.
It should work....its like clamping a zinc brick onto an underwater buoy or anchor...although zinc wears away as it stops the rust....this should just continually apply the charge.
SHOULD
jrm123180
Feb 20, 2011 10:28 PM
jofnui
Mar 7, 2008 06:45 PM
N.Franklin
Nov 2, 2007 01:13 AM
chris
Appearance & Camping Set Ups
Aug 2, 2007 04:21 PM
howellja
Apr 29, 2007 10:52 PM
