couple PS pump rebuild questions
Old Nov 11, 2023 | 05:09 PM
  #21
Extinct's Avatar
RTV wil not work, the pump housing is under pressure and will push the silicone out. If you want to use a liquid sealant use Permatex Moto-seal and follow the instructions.
Old Nov 11, 2023 | 08:58 PM
  #22
miron's Avatar
Cool, thanks for the hint.
Old Nov 11, 2023 | 10:32 PM
  #23
miron's Avatar
Would loctite high flex gasket maker work as well? Says it's good on pressurized equipment.
Also i was wrong, of course, the ring can go in two ways...
Old Nov 12, 2023 | 04:49 AM
  #24
Extinct's Avatar
I don't recall specifically that product but if you want to post a pic or pn I can tell you if I tried it and if it will work or not. I can say almost nothing works except the motoseal and I am still testing it.
Old Nov 13, 2023 | 12:41 PM
  #25
miron's Avatar
Here is the product:
for whatever unsubstantiated reason I trust Locticte more than Permatex.
Old Nov 13, 2023 | 02:32 PM
  #26
Extinct's Avatar
I would not try that, you don't need high flex you need high strength/stiff. That pump gasket is under a lot of pressure and needs to resist pushing out.
Old Nov 13, 2023 | 09:49 PM
  #27
miron's Avatar
sounds good, i'll experiment with motoseal. I also found a store that sells loose gaskets, so will be stocking those, since it looks like my rebuild is a total fail...
Old Nov 22, 2023 | 10:50 AM
  #28
miron's Avatar
So i finally got the motoseal. Another question i have is how much should i torque the bolts? The guy on YouTube is going for 12 lbs/ft but clearly he is eyeballing. Is there a spec for this?
Old Nov 23, 2023 | 06:17 AM
  #29
Extinct's Avatar
There is not a spec but I can tell you from experience if you overtighten it you will crack the rear cover. I would think only tighten it enough to get adequate gasket compression. I can't tell you how much because I have not measured it but similar to the inline thermostat kit I think around 20 ft lbs should be enough.
Old Nov 23, 2023 | 11:53 AM
  #30
Harvlr's Avatar
Yes, unfortunately the lessons we learn from experience are our best lessons.
chubbs878
Mar 2, 2017 07:13 AM
Philschlomo
Jul 17, 2013 06:48 AM
treho54
Oct 20, 2008 02:12 PM
Mountainman
Defender
Apr 16, 2007 10:19 AM
AlecH
Freelander
Mar 1, 2007 04:26 PM
