couple small problems i hope
Old May 7, 2007 | 03:46 AM
love2disco's Avatar
4th Gear
Default couple small problems i hope
hi im new here i did alot of lookin around to find out what i need found some and not others hoping some can help
97 disco is what im working on and hers the list of little things
1.the cruse wont work the light doesnt even come on???
2.it has a 2 button remote and it wont work even with new batterys in the remote???
3.the light in the gear selecter wont work (to light up what gear your in) is there just a light bulb???
4.i put in a new seat on pass side and now the srs light in on (on the dash)???
5.how to get the radio out cant find any to do it tryed best buy, local car radio store no one has a tool
6.last but not least its hard to start some times it will just crank but if you cycle the key a couple of times it will fire right up??? fuel temp,fuel pump,fuel filter or am i lookin in the wrong place havent tried anything yet except ran injecter cleanerin and sprayed thro body inject cleaner inintake while running
any ideas ???????????
thanks
Old May 7, 2007 | 04:12 AM
wease206's Avatar
Default RE: couple small problems i hope
you have a mad motor you need a new EUC have someone pull the code
Old May 7, 2007 | 02:14 PM
okdiscoguy's Avatar
1. Check you vacuum lines, fuses and the voltage at the back of the switch. It might not be getting power, or the light just may be burned out.
2. Has the remote ever worked? THey have to be programmed at the dealer, or someone with testbook.
3. Bulb
4. No idea
5. It is a BMW tool. You can get one at the dealer, or use a small flathead jewler's screwdrive to loosen the screws. If you are replacing the radio, you have to get adapters.
6. Start by checking the fuel pressure.
Old May 7, 2007 | 03:20 PM
Rondo's Avatar
ORIGINAL: wease206
Wtf? Your motor is probably not mad at you nor is it likely bad. If it isn't starting right up then check the three things required for ignition: air, fuel, and spark. How old is your battery? Have you checked its voltage output? Still running old spark plugs, wires, air filter?
Old May 7, 2007 | 07:08 PM
love2disco's Avatar
4th Gear
ok let me see if i have all this
1.the gear selecter has a light bulb i can replace
2.the remote has to go to the dealer (it use to work i changed the batterys 2 times) thinking i got a bad battery
3.and there is small screws in the little holes in the front of the radio you must remove to get the radio out and do you know where i can get an adapter for the radio best buy told me they dont make them
4.pressure a little low thinking i will try a new filtter its been awhile
new bosch plat plugs 2 months ago along with wires battery is a couple years old but seems to crank good and fast air cleaner 3 or 4 weeks old it always starts just some times harder then others[:-]
mikemeyer0
Aug 16, 2017 07:49 AM
Charles68
Apr 3, 2008 08:51 AM
DuplinDisco
Feb 9, 2008 05:47 PM
96SE7Disco
Feb 1, 2008 04:21 PM
JKK
Aug 30, 2005 10:11 PM
