CPS Strikes Again? Please confirm my
Old Dec 26, 2011 | 10:41 AM
jafir's Avatar
Originally Posted by mln01
No, this does not sound like a crankshaft position sensor failure. CKPS does not cause the engine to run rough or throw codes and the Service Engine Soon (SES) light does not come on.
Mine did.
Old Dec 26, 2011 | 01:14 PM
yloDiscoII's Avatar
Job done, problem solved
BUT, Holy Frustration Batman!
My right arm is torn up from squeezing it up in between the frame and the exhaust, and the exhaust and the engine, maybe I need to stop working out?
It seems the designers didn't think anyone would ever have to change this sensor ever without having to pull the truck apart and if it came down to it, and the price wasn't outrageous. I would probably pay to have this done.
Old Dec 28, 2011 | 04:12 PM
yloDiscoII's Avatar
Originally Posted by jafir
It will probably be a Bosch sensor in an autozone bag. Mine was.
...and yes, you were correct. Upon closer inspection, "Bosch" was stamped right on the sensor.
Just another tip for future readers : Be careful when un-doing the nuts from the studs that hold the sensor end in place. I had to contort myself to fit my arm up between the engine and the exhaust, which eliminated any chance of being able to see what I was doing and I ended up bending one of the studs which added extra suspense/time/and frustration having to bend the stud back straight enough to get the new sensor pinned back down.
Old Dec 28, 2011 | 04:14 PM
yloDiscoII's Avatar
Please post in your followup the spacer location that worked for you. Thanks in advance.
Thanks for the help, I was very conscious of this thanks to you and a few of the other threads I read where people had bolted things back up improperly.
Per your follow up request , I bolted it back up just as it was pulled apart. I'm not sure how people have done this incorrectly as I can't see it fitting together properly if bolted up wrong.
FLA Rover
Aug 16, 2013 06:16 PM
AnnelieseMae
Oct 4, 2009 11:33 AM
DG62
Jun 5, 2008 03:52 PM
crownaviation
Sep 13, 2007 10:08 PM
ajh
Jul 18, 2007 08:13 AM
