Cracked Gutter Repair
Old 04-04-2013, 03:51 PM
MONEYMIKE's Avatar
Default Cracked Gutter Repair
I have hair line cracks that allow water to ingress to my passenger side headliner. My question is, what kind of silcone sealant should I apply? .... Like what type of brands and where can I get it? And I need something permanent or is there a better seal for these cracks without using silcone sealant?
Old 04-04-2013, 05:14 PM
Black RTV. But if the water is near the front windshield, the seal around the windshield can leak and water be forced into the head liner.
Old 04-04-2013, 05:26 PM
MONEYMIKE's Avatar
The leak is in the upper passenger side corner of the headliner
Old 04-05-2013, 01:10 AM
Right where mine was. I coated the gutter with sealant, no help. I pried back the plastic strip at top of windscreen and saw where I could add RTV sealant behind it, and that corner piece. I was able to put a clamp on my corner via the front A pillar with door adjar.
Old 04-05-2013, 02:24 PM
MONEYMIKE's Avatar
Ok im test both spots and see where its leaking..... But is this black rtv good: http://www.amazon.com/gp/aw/d/B000FW7V3M
Old 04-05-2013, 04:58 PM
slanginsanjuan's Avatar
i went marine. i used the 3m5200 black on both trucks. it worked perfectly. it's expensive.
it's permanent now and i plan to paint over it when i do the roof.
Old 04-05-2013, 09:01 PM
borchera's Avatar
LR put out a technical advisory bulletin for this repair.
2003 Discovery 133K with high miles services complete.
File Type: pdf
Old 04-05-2013, 09:45 PM
blcp86's Avatar
My 04 is doing the same thing, with the tech order if I go to the dealer will they fix it? Or will it cost me $2500?
Old 04-06-2013, 10:23 AM
it's a good caulking job. the dealer will charge you too much for sure.
Old 04-07-2013, 02:39 PM
blcp86's Avatar
Where exactly should I put the sealant? I don't want to block a drain.
Quick Reply: Cracked Gutter Repair
