Cracked plenum?
Old Oct 13, 2025 | 01:34 AM
KlamathMatt's Avatar
Default Cracked plenum?
There appears to be some cracks in my air intake manifold plenum. I am getting lean codes -0171 & 0174.  Any recommendations to test whether this is the source of my trouble codes?⁷
There appears to be some cracks in my air intake manifold plenum. I am getting lean codes -0171 & 0174. Any recommendations to test whether this is the source of my trouble codes?⁷. Also, what causes these cracks for Future ref? Thx!
Old Oct 13, 2025 | 07:35 AM
redrover75's Avatar
I have never seen that before, if it is cracked through you could clear it up with a grinder and fill with JB weld pretty easily. That is a pretty thick casting, i cant imagine how that happened with out an accident or obvious force. You could try to fill it with flex seal tape or similar as a test to see if that is your leak. It would definitely cause codes if the crack goes all the way through.
Old Oct 13, 2025 | 11:48 AM
Harvlr's Avatar
Personally I might try JB weld for troubleshooting but I would replace that plenum. For sure any leaks there would cause it to run lean.
Old Oct 13, 2025 | 03:15 PM
evil_goat's Avatar
Can you feel the cracks? I had some weird fluid residue/stains that looked similar.
Old Oct 13, 2025 | 06:09 PM
Extinct's Avatar
Yeah, spray some wd40 on those cracks with it running and see if it sucks it in. I have never seen those crack. I have several extra if it really is cracked you can have one if you want to pay the shipping.
Old Oct 14, 2025 | 01:33 PM
nashvegas's Avatar
Wonder if the motor was from an accident damaged car. There’s really no reason that this could possibly crack. Have never seen that in all my years on a P38 or a D2, which echoes what others say here.
Wow.
Old Oct 14, 2025 | 09:43 PM
Best4x4's Avatar
Looks like something someone loosing their temper would do lol
MSGGrunt
Feb 17, 2025 05:41 PM
Poway
LR4
Aug 25, 2023 06:57 AM
Poway
Range Rover L322 (3rd Gen)
Aug 24, 2023 06:59 PM
Jason_B
Jul 10, 2021 12:54 PM
chubbs878
Dec 24, 2015 08:44 AM
