Cracked plug on oil pump case
Old 07-15-2021 | 05:00 PM
dswilly's Avatar
The welding rods are more like brazing or solder. I don't know if they would work for that or not. New cover is the safest bet.
Old 07-15-2021 | 05:04 PM
neuropathy's Avatar
Thank you, I need to make things as easy as possible for me or I'll never manage this. I have a new water pump ready to put on there as well. I just bought the pump recommended here. At the same time, you'd probably clean the pickup pipe and maybe replace the front crank shaft seal if that becomes easy to access at the same time?
Edit: Actually, the crankcase seal is on the oil cover right? It appears to be included with the SKP assembly already.
Old 07-15-2021 | 05:27 PM
Extinct's Avatar
Yeah, may as well change the front seal. Someone will chime in and say change the timing chain, but unless you have crazy high miles or it is seriously loose you don't need to do that.
Old 07-16-2021 | 08:54 AM
dswilly's Avatar
Front seal will be with the new cover. With mine the crank pulley had grooves worn in that caused the seal to leak so watch for this when you take the pulley off. I ended up using a speedi sleev. No leaks.
Old 07-16-2021 | 05:51 PM
Extinct's Avatar
Yeah, if the front cover has grooves, you can either speed-sleeve or position the seal a bit deeper or shallower so it is not in the groove.
Old 07-17-2021 | 06:29 PM
XRAD's Avatar
download and read all pages concerning oil pump front cover repair in the RAVE....
onyx2019
Range Rover Evoque
06-04-2020 09:56 AM
hemicharger69
07-18-2016 03:13 PM
jalodge
04-01-2014 08:07 AM
Robmcin
06-24-2009 02:22 AM
imag
05-12-2006 07:59 PM
Quick Reply: Cracked plug on oil pump case
