Craked windshield cowling nastiness, random objects(?)
Old Jan 6, 2018 | 06:22 PM
mr. choodles's Avatar
Default Craked windshield cowling nastiness, random objects(?)
If you have a cracked windshield cowl, here is what your truck going to show under the plastic after rain. Note, there are no drains so water just collects in the area below the windshield cowling.
By the way, what is that electric plug? There are two of them: one on each side. Is that a hook to the heated windshield? My windshield is not original, so I presume someone did not replace the glass with the OEM version...
Old Jan 6, 2018 | 06:42 PM
OverRover's Avatar
Yes, the connector is for the Heated Windscreen.
Old Jan 6, 2018 | 06:50 PM
emncfi's Avatar
On my 02, there are drains on the sides (basically the back of the fender) that are about 1/2 inch in diameter
Old Jan 6, 2018 | 09:52 PM
mollusc's Avatar
You'll have the plugs even if your truck isn't set up for a heated windscreen. The same wiring setup was used for all models in each year, and extras were added and activated at assembly.
Old Jan 7, 2018 | 05:35 AM
The Deputy's Avatar
Yes, drains are in the inner portion of the fender...and get filled with debris easily.
Brian.
jdwilks
Jan 14, 2017 08:46 PM
aguison
May 24, 2015 05:03 PM
russburcham
Sep 19, 2012 07:07 PM
Apilky
Aug 5, 2008 05:47 PM
Sarge
Jun 4, 2005 07:57 PM
