Crank Bearing #3 - No Lectures Please
I like RoverMasterTech's idea of replacing crank and rod bearings while the oil pan is down to (1) improve oil pressure and (2) increase longevity in a serviceable engine. This post is not asking members to opine on the merits of installing new bearings in an engine with 133K miles.
So, here is my #3 crank bearing. There is visible wear, but is there enough to warrant replacement of all the bearings? If you look at RoverMasterTech's "Main/Crank Bearing Replacement DII" sticky the babbitt on those bearings is wiped. Mine look much better.
Should I replace them?
Quiksilver1850
11-25-2008 01:05 PM
