crank or camsensor problem
Old Feb 6, 2011 | 02:11 PM
hydroplaner2's Avatar
Default crank or camsensor problem
i have a 2000 discovery a plug wire came off the coilpack and ever since that happen the car will not accelerate and backfires thru the intake when you push down on the gas i have replaceced the coil pack and checked the ecu any ideas
Old Feb 6, 2011 | 03:44 PM
You fried something but I have no idea what, start with the crank sensor.
Old Feb 7, 2011 | 09:14 AM
No, it is not either of the crank or cam sensors.
Do a compression test, I'll bet you have a fried/carboned up exhaust valve. If need be then do a leak down test to confirm.
Let us know what your compression numbers are.
lacruiser
Apr 13, 2013 06:24 PM
LuvToDisco
Apr 28, 2010 09:06 AM
rebel1
Oct 7, 2005 09:41 PM
modelwerks
Oct 3, 2005 09:29 PM
devildogrover
Dec 24, 2004 04:48 AM
