Crank position sensor test ??'s
Old Sep 21, 2009 | 09:49 PM
possibly owner's Avatar
Default Crank position sensor test ??'s
Which plug on the ecm do you check the crank position voltage at? The ecm is in the passenger kick panel correct?
I also checked codes, it had a p1884?
Old Sep 22, 2009 | 09:06 AM
1884 is actually a fault code for 8 different issues and will go away on it's own when your issue is resolved.
What is your truck doing wrong, do you have a scanner that can give you real time readings, if so that is the easiest way to verify a problem.
Woody Reems
Jul 14, 2009 08:30 AM
oljohnboy
Mar 30, 2009 08:54 PM
wosmo
Aug 7, 2008 11:24 PM
DiscoOn22s
Apr 19, 2008 05:12 PM
lacruiser
Feb 28, 2008 07:24 AM
