Crank Pulley
I soaked it with PB plaster, and waited, and waited then tried to pull it off and still had no go. Finally took a light tap hammer and tapped it around the edge. The vibration got it off! Now I'm down to 1 tricky bolt for the oil sump. Its the drivers side far back one that is not on a Y axis. It screws in towards the rear axle. (if that makes sense) The bloody tranny cooler lines are in the way along with the exhaust pipe.
Any suggestions?
Any suggestions?
