Crank Pulley
Old Dec 20, 2013 | 11:11 AM
oilspotLR's Avatar
Default Crank Pulley
Hello,
Doing a front cover and oil pan reseal here and I was able to get the crank bolt off, however the pulley is still not budging. I used a crow bar and it still had quite a bit of resistance. What am I missing here??
Old Dec 20, 2013 | 11:16 AM
drowssap's Avatar
if the bolt is out and the belt is off it should slide off, have you tried soaking it with PBBaster yet?
Old Dec 20, 2013 | 11:14 PM
oilspotLR's Avatar
I soaked it with PB plaster, and waited, and waited then tried to pull it off and still had no go. Finally took a light tap hammer and tapped it around the edge. The vibration got it off! Now I'm down to 1 tricky bolt for the oil sump. Its the drivers side far back one that is not on a Y axis. It screws in towards the rear axle. (if that makes sense) The bloody tranny cooler lines are in the way along with the exhaust pipe.
Any suggestions?
benreal
Apr 27, 2012 08:47 PM
94svt50
Apr 9, 2012 04:36 PM
greg409
Feb 24, 2010 12:35 AM
lipadj46
Nov 15, 2009 11:27 AM
shonuff93
Oct 7, 2009 07:24 AM
