need help with compression test
Old Dec 21, 2013 | 03:59 AM
ratijs100's Avatar
Default need help with compression test
Hello everyone,
I need to do tune up for P0305 coming all the time. HG were replaced recently and the car was driving well until it started to throw p0305 code on uphills on high rev. I looked under the hood at night and wires are flashing. Before replacing anything i want to make compression test. I will pull out fuel pump relay, remove plugs and wires, but what to do with the ignition? Connectors on coils are very deep back of the engine and i can't reach them. Is it necessary to turn off ignition for engine compression test and are there any other ways to turn off it except disconnecting the coils?
Old Dec 21, 2013 | 08:11 AM
Disco deuce's Avatar
All I did for my compression test was unplug the wires and remove all the spark plugs then turn the engine over for a few seconds per cylinder and took the highest compression from each. My 3 and 5 cylinders were reading slightly above zero due to a blown head gasket.
bcolins
Jul 13, 2013 08:43 AM
bradman951
Apr 22, 2013 01:07 PM
msm15
Jan 18, 2011 09:54 PM
btbaus
Jan 20, 2010 04:38 PM
afphinfan
Jan 1, 2008 05:58 PM
