Cranks fine but won't fire after head gasket
I just completed a head gasket job on my 01 disco. I have triple checked all connections etc. and it will not start. No smell or smoke coming from engine bay or exhaust. It seems like maybe it is not getting fuel? Do I just need to keep cranking? Or purge the fuel system somehow? I haven't seen any red flags when turning it over...but it will not even hiccup.
Any suggestions will be greatly appreciated. Thanks!
I checked the fuses this morning and none of them were blown. Anything else I can check? I still think it has something to do with the inertia switch and fuel pump. I can't hear it kick on when turning the key and the engine just turns and turns without even a single fire. When I hooked it back up the flashers were on, I then unhooked the battery and reset the inertia switch and that took care of the flashers...what else can I do???
TLMAGE
02-27-2015 09:46 PM
