Crankshaft
Old Mar 11, 2023 | 10:55 AM
Brinkley's Avatar
Default Crankshaft
HI all,
Had oil pump go and wiped out the bearings and a few rods. No. 1 bearing was completely disintegrated and in oil pan and plugged up pick up tube. Really gouged the crank bad. I don't it can be salvaged. Plus I really messed the bearing cap that has the stud on it. It took a lot of pounding to get it out. My question is there a difference between 4.0 and 4.6 crankshaftS? I have a 2003 4.6. I know I'd be better off just buying a new block from atlantic but I just don't have that kind of money.
Old Mar 11, 2023 | 11:01 AM
zski128's Avatar
Yes there is a difference between the 4.0 and 4.6 crankshafts. It has a longer stroke for the rods.
Old Mar 11, 2023 | 11:34 AM
Brinkley's Avatar
Thanks.
Old Mar 13, 2023 | 02:34 PM
jastutte's Avatar
isn't there a way to build a 4.6 using a 4.0 block?
Old Mar 14, 2023 | 07:21 AM
Alex_M's Avatar
Yes. Complete 4.6 rotating assembly will swap over. Crank, rods, Pistons. 4.6 cam is an upgrade too, but keep lifters on their correct cam lobes.
Old Feb 9, 2025 | 11:20 PM
04disco2v8's Avatar
6th Gear
Does anyone have a good place to purchase the crankshaft for the 4.6? Pulling the engine due to an exploded oil pump leading to destroyed bearings and a severely grooved crankshaft, and I was wondering if anyone had a good source. Thank you!
dundee41
Mar 17, 2016 09:58 AM
Mustang196718
Mar 17, 2016 09:32 AM
fishEH
Jul 24, 2015 10:29 PM
primussucks
Oct 31, 2013 07:05 AM
TurboLS1Driver
Jun 17, 2012 08:36 PM
