Crankshaft / harmonic balancer pulley washer?
Old May 13, 2023 | 10:33 PM
Rrr_bhb's Avatar
Default Crankshaft / harmonic balancer pulley washer?
Hey folks, so Im almost done with my updates on timing belt and trying to put the crankshaft pulley back. I somehow might have misplaced the washer. Does anyone know / recommend any replacement washers ? Washer size or spec? Im going to keep looking for my misplaced one but will probably want to order a replacement soon if I cant find it. Thanks in advance!
Old May 14, 2023 | 02:49 PM
Discorama's Avatar
The washer is 44mm in diameter and 13mm thick.
Old May 14, 2023 | 05:05 PM
Extinct's Avatar
Nothing particularly special about it, if you can't find a similar spec one you can just stack to to get the same thickness
Old May 15, 2023 | 12:49 AM
Rrr_bhb's Avatar
Thank you! I was able to get one locally and got the job done. Really appreciate the quick and accurate response.
Tony Luna
May 10, 2023 11:40 AM
ge234
Sep 22, 2015 08:58 AM
jbkroh
Oct 19, 2012 09:40 AM
discobob
Jan 4, 2012 09:25 PM
souljad9
Nov 19, 2008 11:50 AM
