Crankshaft timing gear has slight play.
Old Jul 5, 2025 | 06:58 PM
evil_goat's Avatar
Question Crankshaft timing gear has slight play.
I am replacing the timing chain and gears. The new crankshaft gear that was from atlantic british branded allMakes4x4 seemed bad and fit loosely on the crank with quite a bit of play. The old timing gear (i dont think the original) still has some play (in all axes), but less. Is this acceptable? It allows some slight cam movement independent of the crank. If I hold the gear in place, there is no cam movement. If this is bad, where can I get a good quality gear?
Greg Salmon
May 26, 2021 06:25 PM
Tomzsix
Oct 22, 2017 09:32 PM
Joshua Hollahan
Feb 21, 2017 03:35 AM
MrFlea1
Jan 1, 2012 06:10 PM
Timebus
Nov 21, 2011 06:46 PM
