Crazy little question
Old Aug 2, 2009 | 02:35 PM
NM-DiscoDuck's Avatar
Default Crazy little question
Ok, since replacing just about every sensor under the hood and installing new plug wires, our Disco I has been running great. Last night, the Check Engine light came on and threw the same old 1177 code.
I just looked under the hood and noticed that the cruise control vacuum line had split and come off. So, I trimmed it, put a little lube on it and reinstalled.
Would that vac line make the computer throw a code? It's just too weird.
Old Aug 2, 2009 | 02:46 PM
hilltoppersx's Avatar
nothing to do with the cc vac. the code is Maximum Negative FMFR Correction Fault, what wires and plugs did you put in? how long ago were they put in?
Old Aug 2, 2009 | 03:53 PM
I finally got the Magnecor 8mm wires, and the PO had just installed platinum + plugs, which look fine.
Beemat
Jun 23, 2011 02:29 AM
NM-DiscoDuck
Feb 20, 2010 01:26 PM
redmel
Nov 14, 2005 09:03 AM
jasongilliland
Oct 2, 2005 04:04 AM
Bene
May 1, 2005 04:21 AM
