Crouse control
Old Mar 7, 2006 | 09:28 PM
discovery's Avatar
3rd Gear
Default Crouse control
I have 96 Discovery it runs well, however crouse control system does not function.
Dash board light can be on and off no problem, no activation no clicking sound.
All other switches are ok.
Please let me know any thing can help.
Thanks
Old Mar 7, 2006 | 10:44 PM
mikemeyer0's Avatar
Default RE: Crouse control
Start checking the cruise control vacume lines.
Look at the vacume manifold switch on the brake pedal
Old Mar 7, 2006 | 10:48 PM
NHESS81's Avatar
the vacuum lines are likely cracked....if you look at your throttle body (bronze colored disk thing in the engine bay), you will see a 1/4 inch black hose...this hose leads to a t-piece, with a hose going towards the front of the truck, and one going through the firewall to the cab. these lines are likely cracked or have visible holes in them. go to an auto parts store, bring in a sample of the hose, buy like 12 feet of it,
-1-go home, cut it to the same length as the ones you took off to make it easier, or just cut as you go like i did, and
-2-slide the hose onto the throttle body, brake pedal, and vaccum pump (under the jack in the front, hard to see, but you can put your hand down there, and follow the old vacuum hose to find the little nipple to slide the new hose onto...
-3-then hook them all up to the t-piece.
the hardest parts are getting the new hose down through the jack area to the vacuum pump, and sliding it through the firewall without pissing off the rubber grommet/seal there. this is a very easy fix, you can likely do it in about 15 minutes and it hardly gets your hands dirty too! plus, it will cost about 2 dollars! fixed my 97 right up!
Old Mar 16, 2006 | 11:54 PM
discovery's Avatar
3rd Gear
Hi
Dear NHESS81
You are just great all the things you said about the course cotroler was right I followed the direction as you recomanded I fixed it. works just fine.
Thanks again
Nader
Green Blood
Dec 22, 2018 04:40 PM
Evan5291
Nov 21, 2017 07:59 AM
moorebl
Oct 3, 2014 09:59 AM
gamecockdisco
Jul 12, 2010 08:34 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
