Crower 53229 Camshaft questions
I have a rover p38 engine at a local performance rebuild shop getting built. I have the crower 53229 cam and lifters for the build. He is telling me I need new springs as stock spec is 70lbs and mine are measuring 68lbs. I’ve been scouring the web and this site and getting mixed answers. The crower site shows similar rpm range to stock.
I’d love to hear from someone with experience with this, thanks
Sixpack577 (12-20-2019)
Spring measuring tool may be off a few %s. 2lbs will not make a difference for the revs you will do with this engine so valve float unlikely. Sometimes the extra cam lift requires lowering of the valve guide seal seat, or thinner spring washers. Extra duration won't change that. Agree with above, doing a deep rebuild, replace the springs. Stock will be fine. I suspect that most of torque and power will be low to mid rpms, not at 6000 rpms.
