Crower 53229 Camshaft questions
Old Dec 19, 2019 | 08:18 PM
Fastercat's Avatar
Default Crower 53229 Camshaft questions
I have a rover p38 engine at a local performance rebuild shop getting built. I have the crower 53229 cam and lifters for the build. He is telling me I need new springs as stock spec is 70lbs and mine are measuring 68lbs. I’ve been scouring the web and this site and getting mixed answers. The crower site shows similar rpm range to stock.
I’d love to hear from someone with experience with this, thanks
Old Dec 19, 2019 | 10:14 PM
Frank4's Avatar
I had that cam in a 4.6 from a P38 in my 1989 RR. I don't remember having to buy new springs but maybe your guy knows better than mine did. I'll say one thing though thatcam woke that motor up and sounded awesome.
good luck
Old Dec 19, 2019 | 11:13 PM
If they are weak for stock spec than I would replace them. If your going through everything else on it seems logical to knock it out
Old Dec 20, 2019 | 07:14 AM
Best4x4's Avatar
I personally don’t like the crowler lifters. I’ve had much better success with the crowler cam & OEM lifters vs using their lifters.
Old Dec 20, 2019 | 09:27 AM
XRAD's Avatar
Spring measuring tool may be off a few %s. 2lbs will not make a difference for the revs you will do with this engine so valve float unlikely. Sometimes the extra cam lift requires lowering of the valve guide seal seat, or thinner spring washers. Extra duration won't change that. Agree with above, doing a deep rebuild, replace the springs. Stock will be fine. I suspect that most of torque and power will be low to mid rpms, not at 6000 rpms.
Old Dec 20, 2019 | 11:31 AM
Fastercat's Avatar
Thanks guys. I’ll see about new stock springs than.
ImQuattro
Jan 19, 2024 02:54 PM
Speedsterguy
Dec 8, 2022 09:29 AM
wynhd
Feb 11, 2016 09:22 AM
RicketyTick
Jul 8, 2014 07:21 PM
BCDisco2Lando
Aug 7, 2013 10:19 AM
