cruise control
Old Dec 13, 2007 | 07:16 PM
browndogq's Avatar
Default cruise control
Would or has anyone had a cruise control surge up and down about every 45 sec? I don't know were to start .
Old Dec 13, 2007 | 07:27 PM
bearcatfans's Avatar
Default RE: cruise control
What year?
Old Dec 13, 2007 | 07:30 PM
browndogq's Avatar
Sorry ,03
Old Dec 13, 2007 | 08:20 PM
Darover's Avatar
I know what you mean...gives gas, lets go, gives gas, lets go, gives gas, lets go.......Freekin annoying to the point of not using it.
Old Dec 13, 2007 | 08:33 PM
browndogq's Avatar
I would think thatthis isn't normal but I dont know.
Old Dec 13, 2007 | 08:44 PM
Fonzie's Avatar
My 03' does the same thing. I posed the same question on here a few weeks back and DeepBlueWater (who also has an '03) gave me this response:
As for the cruise control: Mine oscillates only for the first 20-40 seconds as the computer learns the road and then smoothes out perfectly.
However, I haven't found myself on an uncongested freeway since to test it out.
Old Dec 13, 2007 | 09:42 PM
There was a sort of recall on this...when the '03 got the bigger engine, the Discos were shipped out with the cruise ECU still programmed for the smaller engine so it didn't work correctly with the bigger 4.6 engine so the fix was to reprogram the cruise ECU at port fixing the problem. You should have a 'service campaign' label under your hood attached to the radiator support or in that area showing that the procedure was performed on you Disco. Mine has the label so it was supposedly fixed but mine still jerks. Mine works sort of like 'DeepBlueWater's '- It starts out nauseatingly rough then smooths out. There is also a TSB that describes a procedure to make sure that the cruise linkage is properly adjusted. My cruise isn't perfect, dealer suggested a vacuum leak in my cruise system but mine holds vacuum perfectly - so I just assume it is a rough system.
Hope this helps.
-aaron
Evan5291
Nov 21, 2017 07:59 AM
37chambers
Oct 18, 2016 10:52 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
anonimaus
May 9, 2005 10:01 PM
flowers
Apr 12, 2005 04:03 PM
