Cruise control and a/c directional control broken help please.
Cruise control doesnt work it slowly decelerates must be a suction issue i can tell its trying to work because It doesnt slOw as quickly as when youtake your foot off the gas. Also, the directional control for the ac is busted its stuck on windsheild defrost even tho display says feet and head etc. can anyone help?
Land Rover or not makes no difference, a car is a car and working on them is all the same.
Start inside at the brake pedal and follow that vacuum line into the engine bay.
They tend to crack at the connections, you can just snip off the cracked end's and reattach as long as you have enough length.
Lcagee (10-16-2021)
Rave would show you the entire C/C Setup on a D2. It only has one vacuum line! All this talk of brake switch vaccum lines = RRC/D1. You have the electric vacuum pump, vacuum ball, and vacuum hose. The rest is electronic besides the cable linkage. C/C ECU, clockspring, on/off button, fuse, and set/resume buttons.
I have explained diagnosing the C/C on here several times. Search function should show it. Rave manual puts pictures & wiring at your fingertips.
Can you help me locate this. That's a huge document.
Then do you have any clues to why me and other(s) are having problem that our CC shuts down when we turn on the radio? What's the "link" between the two?
