Cruise Control Help!
Old Jan 31, 2014 | 05:55 PM
  #21
SuperSport's Avatar
Here:
http://www.ebay.com/itm/Land-Rover-D...p2054897.l4276
Old Jan 31, 2014 | 06:48 PM
  #22
Jared9220's Avatar
Originally Posted by sjfarbs
No click to best memory , where is the brake switch located exactly? Thanks!
The key needs to be in the on position when you are listening for the brake switch. Also just tap the break. I can hear and fell it around the shifter also when I tap the brake.
Old Jan 31, 2014 | 07:33 PM
  #23
SuperSport's Avatar
That's the shift interlock you hear and feel by the shifter. Prevents the vehicle from shifting out of park without your foot on the brake.
Old Jan 31, 2014 | 09:38 PM
  #24
marizcal's Avatar
hi.. just for the record.... I have been running without the 3rd. breake light for almost six months... and the cruise control works fine... it has been disconnected....
you could check the diaphragm, the one that the rubber hose is connected... works with vacuum from the hose... use a vacuum tool or, no ofense, use your mouth, connect a hose and suck it a little .. you has to feel some resistance and could see the movement of the wire that goes to the throttle body... if no movement or no resistance ... maybe the diaphragm is damaged...
hope thlis help...
Old Feb 1, 2014 | 04:48 PM
  #25
sjfarbs's Avatar
Perfect, thanks for the help! Once it stops freaking snowing and ice storming, I will pull some vacuum through the diaphragm is good. From there , I am guessing brake switch and maybe cruise control motor that pulls the diaphragm.
Old Feb 3, 2014 | 02:10 PM
  #26
sjfarbs's Avatar
The actuator does indeed hold vacuum! So now we are down to brake switch and actuator motor that pulls the vacuum? If the 3rd brake light does not work , it that a sign of the brake switch being bad?
Old Feb 3, 2014 | 02:32 PM
  #27
SuperSport's Avatar
To me, it does not seem so. If the switch didn't work, then the other two brake lights should not work either. Unless, inside the switch, there is more than one connection for rear lights.
What about putting power to the pump and see if that runs?
Old Feb 3, 2014 | 05:36 PM
  #28
sjfarbs's Avatar
That is a good idea. Looks like 5 spades on that connector, any idea which one needs the 12v and which one is the ground?
Old Feb 3, 2014 | 06:26 PM
  #29
marizcal's Avatar
ok.. here I go again,...... check and read at the Rave... in the "DISCOVERY 99MY to 03MY ELECTRICAL LIBRARY"... search for "cruise".... and you get the complete explanation of the control cruise.... also check the electric diagram... see pics...
check the fuses, if not already checked,
engine box... fuse 16 and link 8 ,,,
inside box... fuses 25 and 30 this last one provides the battery for the cruise-ecu...
and last as I understand... the cruise pump .. conector c0228... pin 2 has Earth, pin 5 has battery from the cruise-ecu, pin 4 activate the pump and pin 3 activates a valve... as I read the rave.. correct me if I am wrong... pin 5 is the battery so pin 4 and 3 should receive earth from the cruise-ecu to operate...
hope this info is useful..
File Type: pdf
File Type: pdf
Old Feb 3, 2014 | 06:51 PM
  #30
Jared9220's Avatar
I'm not trying to Hi-Jack your thread but I told you I would update if a new pump was my fix so here goes.
I got my newly used cruise control pump in the mail today. I swapped the pumps and went for a cruise. I hit the set button on the wheel and BANG.... cruise control. It worked great. It's so nice having it working considering that it never fully worked since the day I bought it.
I need to check the cable at the throttle body to make sure it's adjusted correctly. I was reading the RAVE and it says to set cruise cable gap to 4.0-4.5mm. I'm not sure if I'm measuring from the correct point but 4.0mm seems a bit much. Can someone please confirm how to correctly adjust the cables?
