Cruise Control Issue
Old Jul 17, 2007 | 10:29 PM
hoberock's Avatar
Default Cruise Control Issue
I have a 1997 Disco I that has a problem with the cruise. When I set the cruise is will stay on (keep the set speed) then unset itself (cruise light on the switch still on). When I try to reset it (using the steering wheel controls), it won't go on. If I turn it off (using the dash switch) and wait, it will some times work again. I have inspected all the vacuum lines and they are OK. I replaced the cruise computer and vacuum pump. The brake switch seems to be OK. Any ideas what is wrong?
Thanks,
Tim
Old Jul 18, 2007 | 07:45 AM
Default RE: Cruise Control Issue
Time to check and replace the vacuum lines for the cruise control including the one to the switch located on the brake pedal arm.
Pretty common Rover problem with an easy fix.
Mike
Old Nov 13, 2007 | 01:08 PM
hoberock's Avatar
Hi Mike,
Thanks for the info. I replaced all the vacuum lines and no change in behavior. The Cruise CPU and air pumpwas also changed about a year ago (due to the same problem). I now suspect the brake senor, but want to hear your expert opinion. Any other ideas?
Thanks,
Tim
Old Nov 13, 2007 | 02:23 PM
hobiecat's Avatar
I too would like to hear about the brake pedal sensor. I replaced my vacum lines with new. The cruise worked for about a week or two then stopped again. I checked my hose connections and they seem fine. I would like know how difficult the pedal switch is to replace.
Old Nov 14, 2007 | 06:54 AM
Landzu's Avatar
Mine did the same thing the brake switch had backed off
and I put it back forward and glued a rubber end on the plunger.
Old Nov 14, 2007 | 07:53 AM
okdiscoguy's Avatar
X2 on that. My plunger had pushed in as well. Just pull it back out to the fullest and you should be ok.
Old Nov 14, 2007 | 10:23 AM
hobiecat's Avatar
Thanks Landzu and okdisguy, I will try to pull the rubber plunger back out.
b c's Avatar
b c
My 96 stopped working until I fiddled with the brake switch too. It had become slightly unseated in the mounting bracket so that it "thought" the brake pedal was not closing the switch. When I correctly seated the switch in th bracket, Everything worked fine. Cheap fix! I also inspected the switch at the time. Its a relatively cheaply made thing that could easily malfunction. To find out if the switch is at fault, you might disconnect the vacuum hose from it and just plug the hose while you make a test drive. don't forget that the switch is a safty device that will disengage the cruise when you need to stop. Careful!
Old Nov 14, 2007 | 11:20 AM
Landzu's Avatar
ORIGINAL: hobiecat
The rubber plunger was a add on on mine so I would not have the
problem again, its a plastic plunger.
I just glued a rubber piece on.
Evan5291
Nov 21, 2017 07:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
Benhamtroll
Jan 18, 2009 08:01 PM
slangel
Oct 7, 2006 11:55 PM
madas
Aug 27, 2006 04:54 PM
