Cruise Control not stable
Hi all,
cruise control did not hold the speed, so i changed the vacuum lines. Since then the cruise control keeps accelerating about every 5 to 10 seconds. The rpm barely moves but it is noticeable, the L/100km on the ultragauge confirms this.
i removed the cruise control pump and checked the lines again, they are looking good.
then i thought i might be able to check something with the nanocom.
so i connected the nanocom, started the engine, enabled the cc button and opened the ‘hella cc’ option on the nanocom.
went to ‘inputs’ and saw the following while standing still with gearbox in neutral and handbrake on;
The up and down sequence of the roadspeed shown in the video is almost the same sequence my cruise control is accelerating.
what are your thoughts?
JUKE179r (10-21-2021)
What Best4x4 said... Mine was doing the same thing--took almost all of the slack out of the cables and it's much better. Actual speed doesn't change much at all now and while the engine does still surge it's not nearly as much or as often. Seems to do best going uphill, oddly enough, when it has to keep some extra power on. Holding a speed at cruise on level road is where it "hunts" the most.
Plus, could it also be the actuator, which is a separate component? Or do you recommend replacing both? And, same question about the failure rate for the actuators.
I took a 320-mile roundtrip last Friday to Durham. The cruise control worked on the way to Durham, but felt weak. It didn't work on the return trip later that day. I'd try to set the speed and the speedometer would drifter lower and lower. Thanks.
