Cruise Control Problem
Old Apr 25, 2013 | 12:59 AM
herbg's Avatar
4th Gear
Default Cruise Control Problem
Hi guys I am new here, have a problem with my D2 V8 Auto 2000 model, have read the threads and found the hose was cracked, thought ...replace and problem solved...but no it still isnt working, any other sugestions...HELP PLEASE
Old Apr 25, 2013 | 08:36 AM
You could have a bad or no voltage for vacuum pump assembly, the cruise makes vacuum, it does not use engine vacuum. Or many other tiny things could be bad. The RAVE shop manual has the whole story starting on page 360 to 376 out of the 1529 total. I have attached one of those pages. If you need the rest, the whole manual is a free download in my signature.
BTW, welcome. This part of the forum is not for tech questions, so I will move your thread.
File Type: pdf
Old Apr 25, 2013 | 08:24 PM
mtrdrms's Avatar
Is the fuse good? Does the button light up when pressed?
Old Apr 25, 2013 | 10:49 PM
Street Wolf's Avatar
Replace the pump, odds are that is the issue.
Old Apr 26, 2013 | 03:44 AM
herbg's Avatar
4th Gear
Thank you and my appologies...I am new to forums....still finding my way around
Old Apr 26, 2013 | 03:51 AM
herbg's Avatar
4th Gear
Savannah, thanks for that page...however i have NO idea how to get to that manual in your signature....think you can help "a junior member"....
Old Apr 26, 2013 | 07:46 AM
try this link, select wokshop manual under D2
Land Rover Manuals
Evan5291
Nov 21, 2017 07:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
whurst79
Jun 18, 2008 06:51 PM
hanivw
Apr 23, 2008 02:02 AM
totalperformance65
Jun 9, 2006 04:58 PM
