Cruise Control Pump Wiring
Old Jun 26, 2018 | 03:29 PM
robert.juric's Avatar
Default Cruise Control Pump Wiring
I'm finally getting around to fixing my cruise control. I'd like to verify my cruise control pump by attempting to trigger it while the vehicle is off. I pulled this diagram from the RAVE, but I'm not exactly sure how I should wire some jumpers.
My thought would be to connect the blue terminal to positive battery terminal and touch the black/red to ground to trigger the vacuum pump? And then touch the green wire to ground to trigger the dump valve? Of course by the wires, I mean the terminals on the pump which had the wires connected to them.
Old Jun 27, 2018 | 10:29 AM
OffroadFrance's Avatar
Robert
I have a TD5 so not the same CC but be careful you don't blow up the engine management ECU in your endeavours, it's expensive.
Old Jun 27, 2018 | 10:50 AM
No I was going to note which wires went to which terminal on the pump itself. Then disconnect the harness from the pump and connect jumpers from the pump to the battery.
The worst I could do is blow up a leaking pump. Best case I could verify it's creating and holding vacuum.
Old Dec 14, 2022 | 03:23 PM
amoody's Avatar
5th Gear
Hey Robert! Any luck with this? I was going to try the same thing with my CC pump.
Old Dec 15, 2022 | 08:59 AM
Sandman614's Avatar
Yes this should work, make sure to unplug the pump from the harness and test on the pump itself. You should only need pin 4 and pin 5 on the pump itself.
Old Dec 15, 2022 | 09:09 AM
rynoman1's Avatar
check your 3rd break light before anything... I spent a long time trying to figure why my cruise wouldn't work... If the bulb is loose or burnt out it disables your cruise control....
Old Dec 15, 2022 | 10:22 PM
longtallsally's Avatar
I’ve heard this before, but based on my real world experience with my latest D2, it’s not true. The 3rd brake light was out in my ‘04 at the time of purchase and on the fly and drive of over 1k miles, the cruise worked the whole way with zero issues.
I think the OP has the right ideas, though. When I’ve fixed other systems, it has been either:
- The vacuum plenum
- The other vacuum lines
- The pump itself
- The clock spring behind the steering wheel
- The brake switch
Diagnosis is fairly straightforward working your way from the switch on the cluster, to the computer, to the clock spring (and steering wheel controls), to the stuff under the hood. From my research in the past, it seems to mostly be either the clock spring or the stuff under the hood.
Old Dec 16, 2022 | 08:32 AM
rynoman1's Avatar
- The vacuum plenum
- The pump itself
- The brake switch
At least for me on my '03 if it's out then it disables cruise. I can take it out and drive it and cruise wont work every time. Its worth a shot as for me its a fix and hopefully can help someone else
Matt927
May 21, 2016 08:10 AM
notny41
Sep 10, 2014 09:49 PM
nelsontod
May 17, 2012 05:25 PM
errose2002
Nov 17, 2010 08:14 PM
Danny Lee 97 Disco
Apr 13, 2010 01:37 PM
