Cruise control shuts off
Old Dec 6, 2007 | 01:41 AM
Nitro96's Avatar
Default Cruise control shuts off
96 Disco with 140k, Cruise will work fine when first started and continues for about 20 miles or so then kicks out and will not reset. Checked and replaced the hoses, system holds vacumn. Any other things I should check? Relays?
Old Dec 6, 2007 | 10:18 AM
okdiscoguy's Avatar
Default RE: Cruise control shuts off
Check your brake switch. The little plunger on mine was not pulled out all of the way when I got it, so I had constant brake lights. There is one for the cruise that can be pushed in as well..Make sure it is out all of the way.
Old Dec 6, 2007 | 02:34 PM
Landzu's Avatar
ORIGINAL: okdiscoguy
I think its that also.
Old Dec 12, 2007 | 01:19 AM
Nitro96's Avatar
Checked the brake switch, it is good. Any new ideas?
Old Dec 12, 2007 | 04:14 AM
mordor110's Avatar
If you have a manual trans there maybe an interlock switch on the clutch pedal too so the engine doesn't try and explode when the clutch is disengaged? I know Honda's have this. I've not looked on the Disco though?
Old Dec 12, 2007 | 11:46 PM
Nitro96's Avatar
No, it is an automatic. Seems more to be someting like a relay orECU problem perhaps as it works fine till everything gets warmed up real well. then it will kick out and not reset till the next time i drive it.
Ron
scottcd1
Jun 15, 2014 09:51 PM
klh113
Mar 28, 2011 02:08 PM
xkelley
Mar 29, 2009 09:03 PM
george99
Jul 12, 2007 06:17 PM
Rover9
Oct 17, 2006 02:18 PM
