Cummins Diesel Repower Disco II
Old May 24, 2017 | 03:25 PM
Cullen's Avatar
Lightbulb Cummins Diesel Repower Disco II
Good Afternoon,
I am just now starting to explore the idea of building my dream daily driver. I am interested in taking the soon available 4 cylinder Cummins R2.8 and putting it in a 2004 Disco II. Full transparency, this is way past my skill level so I will be relaying on a shop ( not yet determined ). Clearly this project has not started, I am posting looking for feedback I plan to find a very clean 2004 disco II. I am confident I can find one for sub 6K. The crate motor should be around 7k. Can anyone recommend a shop that would do well with a project like this? Location is not that important, I can get the motor and rover basically anywhere in the US. Simply focused on a high quality build. Any advise is appreciated!
Cheers!
Old May 24, 2017 | 03:27 PM
Alex J's Avatar
Where are you located?
Old May 24, 2017 | 04:31 PM
Disco Dad's Avatar
Trailhead 4x4 might be able to help.
Old May 24, 2017 | 04:43 PM
KingKoopa's Avatar
Are you going to bump the power some? I'm surprised at its advertised output, or lack thereof.
Old May 24, 2017 | 04:51 PM
Mskembo's Avatar
This is my plan as well. It's not going to be too hard a of a swap from everything I've seen. Engine mounts and engine to transmission adapter and exhaust are things that will need to be fabricated. Other than that I think the wiring will be a breeze.
Old May 24, 2017 | 05:07 PM
dgi 07's Avatar
Subscribed to see how far this goes
Old May 24, 2017 | 05:10 PM
Mskembo's Avatar
The advertised output is about the same as the Rover V8, but in a more usable powerband than our trucks currently have. But you are right that a diesel of that size is capable of producing much more power.
Old May 24, 2017 | 05:26 PM
KingKoopa's Avatar
True. Personally I a sub 350ft/lb power plant wouldn't even blip my radar for the effort and money Involved with a conversion. But if you can coax that kind of power out of the Cummins reliably and easily (which I'm confident you could do), then by all means hand me a beer and let's get to it lol.
Old May 24, 2017 | 06:08 PM
Mskembo's Avatar
I'm sure you can get those torque numbers out of that engine pretty easily. My plan is to do the diesel conversion and run the engine stock for a few months and then start adding power judiciously.
Old May 24, 2017 | 08:23 PM
Cullen's Avatar
Moving to Denver CO in a few months from Jackson MS
