Custom subwoofer box, amp rack, and front stage build in my D2
This may belong in audio/visual but this is D2 specific so I figured I’d post it here. The 1st and 2nd pic is the mostly finished product and the following pics are from the build process.
So first I started on the subs. This build is all about sq and a little about spl. So I chose Stereo Integrity for the 2 12’s.
Stereo Integrity SQL 12. The mounting location What i used to seal the air vent A layer of fiberglass and stone start of the box About 5 final layers here How I got around the seatbelt Back side near door added Glass and resin the inside for water resistance and strength
Figuring out total airspace Checking size for airspace math Front Back Front In truck without face I only had one sub at first. So I used the gasket for a template Here you can see the face didn’t sit flush with the fiberglass because I miss measured BUT fiberglass is forgiving and allows me to patch it Double baffled the front face (2 3/4in mdf on glued) In the truck with seat down With seat up
Great work, and I don't even have any interest in car audio! I noticed that you have a load space rack suspended from above, I fabbed one of those up too (my first ever welding project), it really helps storage in the back now that you can take advantage of the D2 height.
