Cutting out on acceleration
Old Mar 18, 2015 | 11:44 PM
adamharo's Avatar
Default Cutting out on acceleration
Hi Everybody,
I have a '99 Disco 2 with 170,000 miles on it.
When I accelerate sometimes I notice it will briefly cut-out somtimes. The RPMs drop and than it picks up again. It seems to happen more often when I am accelerating faster.
Any thoughts on what would cause this?
Old Mar 19, 2015 | 06:48 AM
martin12's Avatar
Just guessing but could be something like dirt or something in the line, clogged injector, plugs old, I would say check the fuel filter but far as I know the disco 2s don't have a filter they just have the sock in the tank (at least on the 2001 I have). Someone with more experience will probably jump it and point you to the right way.
Old Mar 19, 2015 | 07:20 AM
dusty1's Avatar
Sounds like fueling issue. How long has this been going on/ multiple tanks of fuel?
Do you have any electrical issues?
Do you have check engine light on? Codes?
Old Mar 19, 2015 | 09:42 AM
adamharo's Avatar
Thanks for the replies.
It's been going on for about 6 months. No check engine light. The car runs great overall and this seems to happen when i really put my foot into it.
Old Mar 19, 2015 | 10:06 AM
martin12's Avatar
Maybe the truck is hesitating to give you time to hold on to something before take off.
Old Mar 19, 2015 | 10:25 AM
adamharo's Avatar
Ha ha Martin. I have a big wheel that accelerates faster than this truck.
It doesn't happen right at take off it happens once its in third or fourth gear.
Old Mar 19, 2015 | 11:14 AM
martin12's Avatar
Well do you run any kind of fuel cleaner or injector cleaner every other fill up? I try to run something from lucas or seafoam at least once a month, don't know of it helps or not.
Old Mar 19, 2015 | 11:28 AM
Alex_M's Avatar
I've had the same thing going on for some time now. Seafoam didn't seem to help. I should've tried rebuilding or replacing the injectors while I had the engine torn down for HG, but I didn't. Someone else I talked to about it recommended it might be the MAF, but I don't have any codes so I find that unlikely.
Old Mar 19, 2015 | 04:04 PM
dgi 07's Avatar
sound like fuel....won't do it at idle huh?
Old Mar 19, 2015 | 07:27 PM
adamharo's Avatar
Doesn't do it at idle. Only when i put my foot on it during acceleration. I took the MAF sensor off awhile back and cleaned it with seafoam.
john1doherty123
May 15, 2008 07:10 PM
A Team
Nov 13, 2007 08:45 AM
ChrisW6
Sep 29, 2007 12:26 PM
westernsun
May 27, 2006 04:24 PM
landrover
May 14, 2006 12:20 PM
