Cyl.Head Bolt Tightening Sequence?
Old Oct 29, 2007 | 04:25 PM
dcnellie's Avatar
Default Cyl.Head Bolt Tightening Sequence?
I have a small leak after having my Cyl. heads replaced a few months back. Is there a bolt tightening sequence for putting the Cyl. heads on - like on BMW's?
Thanks.
Old Oct 29, 2007 | 04:31 PM
98roverguy's Avatar
Default RE: Cyl.Head Bolt Tightening Sequence?
Yes, almost all heads have a tightening sequence. I have a DI so can't tell you what the sequence is for a DII but someone will.
Old Oct 29, 2007 | 09:01 PM
Jst4fun's Avatar
This is copied from my RAVE CD. If you are doing the head gaskets I would strongly recomend getting the RAVE CD. Do a search, you can download it free or by it for around ten bucks (sorry don't remember where mine came from.)
Reassembly
1.
Fit cylinder head gasket with the word TOP
uppermost.
CAUTION: Gaskets must be fitted dry.
2.
Carefully fit cylinder head and locate on
dowels.
3.
Lightly lubricate new cylinder head bolt threads
with clean engine oil.
4.
Noting that bolts 1, 3 and 5 are longer than the
remainder, fit bolts and tighten in the sequence
shown to 20 Nm (15 lbf.ft) then turn through 90
, then a further 90 °. CAUTION: Do not
tighten bolts 18
0 in one operation.
5.
Clean the push rods, Lubricate ends of push
rods with clean engine oil, and fit in their
removed order.
6.
Clean bases of rocker pillars and mating faces
on cylinder head.
7.
Clean contact surfaces on rockers, valves and
push rods.
8.
Lubricate contact surfaces and rocker shaft
9.
Fit rocker shaft assembly and engage pushrods
l
Maximum cylinder head warp = 0.05 mm
(0.002 in).
Note: Cylinder head can be refaced to 0.50
mm (0.02 in) maximum below head height
See cylinder head overhaul.
10.
Fit rocker shaft bolts and progressively tighten
to 40 Nm (30 lbf.ft).
11.
Connect ht leads to spark plugs in their correct
fitted order.
12. RH cylinder head:
Position alternator
mounting bracket, fit bolts and tighten to 40 Nm
(30 lbf.ft).
13. RH cylinder head:
Fit auxiliary drive belt
tensioner.
14.
Fit inlet manifold gasket.
ENGINE - V8, OVERHAUL, Gasket -
inlet manifold.
Old Oct 30, 2007 | 09:03 AM
dcnellie's Avatar
This is great - thanks for the info. I already had the heads put on but don't know if the sequence was done right. I don't know why else it would have a small leak. Once again, thanks for the great info!
Old Oct 30, 2007 | 12:00 PM
okdiscoguy's Avatar
if you had the head gaskets done, it may seap a little. Watch it, and do something if it continues. It may stop...
Old Oct 30, 2007 | 09:52 PM
Jst4fun's Avatar
No problem! Hope they are seated properly.
Again try to get the RAVE CD, very helpful along with doing a quick search on this forum
Regards,
Nick
Old Oct 31, 2007 | 10:40 AM
dcnellie's Avatar
Have you ever used any of the "stop leak" products? I have always been afraid of putting something like that into the system. My Russian Indy said not to worry about the leak cause it's small (about the size of a nickel to quarter) and just check it ever so often.
Old Oct 31, 2007 | 10:46 AM
okdiscoguy's Avatar
ORIGINAL: dcnellie
I wouldn't do it. The radiators are prone to clogging as it is...Plus, a buddy once bought a car that had that junk in it. It all collected on the top of the thermostat, and it wouldn't let the T-stat open when his wife was driving it. Toast...
Old Oct 31, 2007 | 09:14 PM
Jst4fun's Avatar
Also depends on what "stop leak" product is used. Your LR should have Dex-cool in it (the pink stuff) and some stop leak products are specifically designed for the green collant which means it wont "coagulate" in the pink stuff anyway.
I hate leaks, it would annoy me... :-)
Regards,
Nick
focusontheworld
Oct 21, 2012 01:00 AM
heilansodger
Jun 3, 2011 08:47 AM
co556guy
Feb 4, 2009 08:01 PM
loic
Jan 26, 2009 10:20 AM
detcord
Sep 29, 2008 08:26 AM
