CYLANDER HEAD BOLT TORQUE
Old Sep 18, 2007 | 03:48 PM
aublec22's Avatar
Default CYLANDER HEAD BOLT TORQUE
I have been looking but i can't find hoe tight to put the cylander head bolt?? I am changing my leaky head gasket any body know for sure 01 disco se II?? THANKS AGAIN
Old Sep 18, 2007 | 07:08 PM
dirtyduk's Avatar
Default RE: CYLANDER HEAD BOLT TORQUE
First you need all new head bolts, they are stretch bolts and should only be used once.
Torque or procedure is = 15 ft lbs in the required sequence, then 90 deg turn in sequence and another 90 deg turn in sequence.
Old Sep 14, 2011 | 10:02 AM
hylandtk1's Avatar
What is the sequence of the head bolts?
Old Sep 14, 2011 | 10:05 AM
Don't even attempt to do this job unless you have a shop manual or Rave CD are it will turn out to be a mess.
There are a few other steps, not listed in any of the manuals that should also be followed to save you some grief later, if interested send me your number and I'll walk you thru them.
Old Sep 15, 2011 | 09:04 PM
hylandtk1's Avatar
I have the torque specs and sequence now but (Disco Mike), you mentioned that there are a few steps not listed in the Rave Manual that are important. I would love to know these steps before I screw everything up for myself, but I do not know how to send you a message with my number so you can walk me through the steps. I am so new to this site I am still learning. Thanks again
Old Sep 15, 2011 | 09:20 PM
click his name and a box will open, one option will be to send private message...
Old Sep 15, 2011 | 09:30 PM
lordmorpheus's Avatar
It would be nice if Mike posted these few other steps not listed in any manual, so others will know about them when replacing head gaskets. It would be a waste of time for someone to have to post "Replacing head gaskets: need to contact DM to find out other steps" then wait for a call from Mike before beginning, every time a member is replacing the head gaskets, which is almost a weekly occurrence here.
Old Sep 16, 2011 | 07:27 AM
antichrist's Avatar
Originally Posted by lordmorpheus
It would be nice if Mike posted these few other steps....
People have been telling him that for years. Save your breath. It's an ego trip and you can't change people.
RicketyTick
May 30, 2014 09:01 AM
FlyingZebra34
Jul 6, 2013 04:07 AM
focusontheworld
Oct 21, 2012 01:00 AM
kraelo
Apr 1, 2008 12:02 AM
sunshineking
Jan 2, 2008 06:52 PM
