Cylinder 1 Misfire Help
Old 02-16-2022 | 04:42 PM
kgov's Avatar
Default Cylinder 1 Misfire Help
Started getting Cylinder 1 Misfire code P0301 today on my discovery 2. I redid the whole top end at 111,000 miles including head gasket, valves, ignition wires, spark plugs and all relevant gaskets. This was in 2016. The truck doesn’t get many miles and now has 145k in 2022. Im trying to figure out what could be the issue. I didn’t replace the coil pack when I did it and I’m not sure the lifespan for the plugs and wires being it’s been 6 years but only 35k miles. Any help would be appreciated.
Old 02-16-2022 | 07:39 PM
Extinct's Avatar
Normal troubleshooting. Swap known good with #1. Plugs (#3), wires (#2), coils, injectors (#3), in that order. Do one at a time to see what changes.
Old 02-16-2022 | 09:38 PM
kgov's Avatar
ok yeah i was gonna check the spark plugs and swap coil wire tomorrow. I don’t have a spare spark plug that matches to replace but I could swap it with another cylinder I guess. I was also curious if I need to swap the coil wire with a specific cylinder or if it doesn’t matter.
Old 02-16-2022 | 11:13 PM
Harvlr's Avatar
As long as the wire is a similar length it won’t matter.
Old 02-17-2022 | 12:24 PM
kgov's Avatar
What are some recommended spark plugs these days?
Old 02-17-2022 | 03:42 PM
kgov's Avatar
none of them will reach as it’s cylinder 1 and all the others coil wires are shorter.
sdtimb
06-11-2021 10:34 PM
Luckyjayb
07-16-2017 10:10 PM
Mikey1976
05-27-2010 07:52 AM
r2racer
04-10-2009 08:53 PM
chvy383
Freelander
12-26-2008 03:40 PM
Quick Reply: Cylinder 1 Misfire Help
