Cylinder 6 steam cleaned
Old May 30, 2015 | 03:51 PM
WaldoWilburforce's Avatar
7th Gear
Default Cylinder 6 steam cleaned
2000 Disc 2 with 100k miles.
To make a long story short, the truck overheated and I have ended up doing a head gasket job. I got the heads off today; there were no obvious gasket failures and no. 6 is steam cleaned, which doesn't sound too good for the home team...likely a cracked block/slipped liner from what I'm reading here.
So what's the consensus? What are my next steps? Do I bother even getting the heads checked or do I zip it back up and try my luck with some mechanic in a can? Thanks in advance for the help.
Old May 31, 2015 | 07:56 AM
RoverMasterTech's Avatar
Back together and blue devil it.
Old Jun 1, 2015 | 05:44 AM
drowssap's Avatar
no coolant near #6 did you check the gasket good?
Old Jun 2, 2015 | 11:05 PM
7th Gear
Thanks for the replies. I was in a little shock when I made the first post in the thread. I've calmed down a little now.
There wasn't any damage to the head gaskets - they looked virtually new. The P.O. actually had them changed at 40k miles under warranty; it doesn't appear that the heads were machined at that time.
I'll also add that although the truck sat for 2 weeks before I dug into removing the heads, the cooling system was significantly pressurized when I started to work. Considering this and the steam cleaned cylinder, it really makes me think there's a crack that opens up as the block heats up and then as it cools, the crack seals back up and holds that pressure in.
Im not sure I've even evaluated all my options here. Man, if I had a crystal ball, it sure would be easier to decide what to do.
Old Jun 3, 2015 | 05:28 AM
drowssap's Avatar
a very common problem with this engine is cracks inside the head bolt holes; after head gasket replacement.
mostly cause by improper installment of the new head gaskets (hydro-lock or improper torquing procedures).
So yes; when hot and under pressure they leak from the actual bolt holes or the coolant comes up between the liner and the block.
Old Jun 3, 2015 | 09:41 AM
Racer X's Avatar
That makes me sad, because the one time I towed a pretty heavy load for about 120 miles, I noticed that I had coolant around one of my outer head bolts, and my coolant was about 1/2" low. It's only happened once in the almost 20k miles since I've had the HG replaced, but still...
Old Jun 3, 2015 | 11:29 AM
drowssap's Avatar
sorry
rover123
Jul 1, 2014 04:37 AM
pinkytoe69
Sep 29, 2013 10:59 AM
BC D2
May 5, 2011 09:32 PM
Satisfying Pie
Jan 8, 2011 11:24 PM
mainstreammediacon
Jan 11, 2007 09:40 AM
