D1 brake question
Old Nov 2, 2009 | 12:08 AM
jasons's Avatar
Default D1 brake question
I had a guy replace my master cylinder on my D1. He used Dot 3 fluid and blead the brakes at the master cylinder where the steel tubes go into the ABS. Now my brakes are spongy and I have an ABS light on. I never had an issue with the ABS light before. What do I need to do to try to get this fixed? I bought two large bottles of synthetic Dot 4. I sure hope I can get the ABS light off and nothing is messed up.
Jason
Old Nov 2, 2009 | 07:24 AM
kenk's Avatar
How long was the dot 3 in there? If you caught it quick enough, might do it just flushing with the dot 4.
I've also read that sometimes you need to cycle the abs pump to fully bleed the air out, which of course takes a special computer to do. But thats just what I read, no first hand experience
IMO, take it back to who did it and make them flush it for putting in the wrong fluid
Old Nov 2, 2009 | 08:21 AM
Take it back and pitch a big b itch.
Make him flush it and put in DOT 4, which is what it calls for in the owners manual.
Old Nov 2, 2009 | 12:57 PM
Eurotrash's Avatar
You need to do a complete bleed of the system starting at the rear right wheel,left rear,right front ,left front.
Old Nov 2, 2009 | 02:16 PM
There is nothing to add to this thread, someone screwed up and may have caused you some brake expense, get them to fix it and let us know how it goes.
SolAeon
Jul 10, 2012 09:05 AM
ctystrickland
Feb 15, 2011 07:54 PM
tibyABv6
Jan 7, 2011 06:02 AM
Florida04RR
Mar 10, 2010 06:09 AM
bigbris1
Jul 3, 2007 08:02 PM
