D1 Normal Idle RPM's?
Hey guys. My D1 idles at 500-600rpm. Is this normal? When I come to a stop sign or just pulling into the driveway the oil pressure light quickly flickers 2-3 times. When driving it does not come on. Could this be the IAC going bad? Also, when starting it cold, it immediately goes to 1900-2000rpm and gradually decreases as the temperature increases. Is this normal? Thanks guys.
The tach on the dash is not accurate, it is off by 50 to 200 rpm so the only way to get a truly accurate engine speed is at a shop.
I would have the oil pressure tested first.
As for the higher rpm when cold, yes it is normal. And when your IAC goes bad the trk will not idle, it will run above 550 rpm but not below 550 rpm.
willypilgrim
12-12-2013 12:53 PM
