D2 with 2005 title
If you check under the hood there is a plate with actual year of manufacture which in most/many cases is one year earlier than the year of registration, e.g. a 2003 registered D2 in 2003 was actually manufactured in 2002. Usually they were sitting in a field somewhere before delivery to the main agents.
Last year for DII is 2004, 2005 it's a LR3. Just run the VIN and you will confirm the year/make/model. Also look at the sticker/decal in the drivers door to see the build date (see pic).
If the title says 2005 have the owner correct the mistake BEFORE you buy it! Good Luck
Here is a 2005 LR3 > https://parkersburg.craigslist.org/cto/6046308898.html
I can't tell you how many Rovers I've bought over the years where the owner insisted that it's a particular model year and were wrong. Most of the time it's because the plate on the front door might have a build date of 7/03 or something like that. People don't understand that vehicles are often build months in advance of their model year release date. I had a brand new '94 RRC that was built in 6/93 but it was a '94 model year Range Rover.
