D2 ABS modulator/brake bleed question
Old Jun 6, 2015 | 07:49 AM
RoadDog's Avatar
Default D2 ABS modulator/brake bleed question
Hi All,
Sorry if there's a cross-post I'm a newbie here.
I just replaced the ABS shuttle valve switch in the ABS modulator of my 2001 D2. Question is: What is the next step to get my brake system back online? I lost about 2/3 quart of Dot 4 in the process and my modulator is probably close to empty at this point. I read the WARNING in red in the Disco II Workshop Manual and it says Testbook/T4 must be followed if the modulator has been removed; well that is not an option. I was just going to bleed the brake system on the four wheels. Recommendations?
Thanks!
RoadDog
2001 D2 115k
Old Jun 6, 2015 | 08:01 AM
stuckntx's Avatar
Did this a few weeks ago. I bled the brakes as per the rave manual and all is well. Good luck.
Old Jun 6, 2015 | 11:12 AM
RoadDog's Avatar
I have been unable to locate a RAVE manual online that is operational; even the one posted on these forums. I think LR took them down.
Old Jun 6, 2015 | 12:41 PM
BusaRider's Avatar
http://www.landroverresource.com/doc...hop_Manual.pdf
I just downloaded it now..... To check
Old Jun 6, 2015 | 02:55 PM
Dave03S's Avatar
The alternate method to the Textbook is to activate the ABS between rounds of bleeding.
Here is the procedure:
Bleed brakes in order that RAVE specifies... Keeping the level up in the reservoir.
In a large parking lot or quiet road put the truck in LOW RANGE. Accelerate to 20mph or so and engage the Downhill Decent Control and let it run until the truck slows down most of the way.
Park and rebleed the brakes in sequence.
Repeat as necessary.
This will make sure the fluid flows through the entire system.
Old Jun 6, 2015 | 04:58 PM
ralphobell's Avatar
You can bleed the ABS with the Autocom. Do a search and you will find how to order and install the software. Under $100.00 Takes all the hassle out of bleeding the entire system.
Old Jun 6, 2015 | 07:49 PM
RoadDog's Avatar
FIXED!!!
THANK YOU ALL for your input!
After replacing the ABS shuttle valve switch & checking for leaks I bled each caliper by lifting each wheel one by one pumping the brakes, then bleeding and feeding the Dot 4 as needed and ran the engine and pumped the brakes between each bleed.
I drove it around the neighborhood and the brakes were normal without further drain on the reservoir.
Thanks again!
RoadDog
2001 D2 SE 115k
3 Amigos are gone too!
RoadDog
Jun 6, 2015 07:26 AM
earlyrover
Apr 8, 2013 02:04 PM
corbin
May 22, 2012 11:21 AM
sayeedA
Feb 25, 2012 12:35 AM
Willie 00D2
Sep 12, 2008 06:35 PM
