D2 auto shift quadrant mod
I thought I'd started a thread on this, but apparently, I buried it somewhere else...
On my '00, the "pull-through" shifts on the autobox are D->3, and 3->D.
This is a bit annoying to me, for 3 reasons:
The FMVSS on automatic transmissions is 102, but it specifies only the order, not which stops must require an extra action (push button, pull column shifter towards you).
- Substantially every other automatic car I have driven in 27 years was R->N->D, D->N,
- That makes it much easier to bump in and out of neutral without accidentally going into reverse (which I *almost* did, once, while still coasting down, but I luckily have good reflexes, and
- The manual *actually suggests* that you idle at stoplights in Neutral.
In related news (as I reread the AT section of the RAVE), if you've ever felt like your 4-speed auto has 6 or 7 gears...
remember a) that it has a lockup torque converter, so you'll feel it going from "4th into 5th"...
and that it backs the engine torque off slightly before a shift (I can often feel this happening in both the 1-2 and 2-3 shifts).
importdave
09-25-2014 10:18 PM
felipenaves
03-20-2007 01:37 AM
