D2 Headgasket help....
Sorry for all the questions... I feel like a noob! lol I guess I am with regards to this job. With regards to the Air cond Compressor, must you completely remove the AC hoses?
Discovery II Head Gasket Kit - Land Rover Discovery Parts And Accessories At Atlantic British
There is no upgrade, your 2003 came out with composite head gaskets. Older discos did not, hence the reference about better head gaskets for the older models.
You also need a head bolt set.
You can also try Will Tiller for a hg and bolt set.
Normally you do not clean the pistons while they are in the block, only if they are out. The reason being you may dislodge deposits that fall between the piston head and cylinder wall and can cause damage there. The better option is to do a induction cleaning once you have the engine running again. You can clean the heads and valve covers while they are off.
