D2 Headgasket help....
Scored on two used SAI manifolds!
On to the next problem... I've removed the upper intake manifold, front AC/ PS brackets, Fan and cooling lines/hoses to Intake manifold. I don't see the disconnect to the fuel rails... Any suggestions?
I was reading "Engine refresh" by Paulp38A.com, he recommended replacing the tappets while doing the HG job and using the silver Payen valley gasket instead of the black composite. Any ideals on this? I'd rather do the job right and only once.
That reminds me of another great tip that I read about but it was too late for me to use:
Cut the heads off of four of the old head bolts and thread them into the block to use as guides when reinstalling the heads.
That's a great tip!!! Much appreciated. I was starting to think That I bit more than I can chew!!!
