D2 Headgasket help....
Old May 5, 2011 | 03:07 PM
  #21
badicedog's Avatar
Yup! that be the one... lol
Old May 5, 2011 | 03:10 PM
  #22
Bundu's Avatar
Banned
$200 says you're going to rethink fixing yours
Check the parts guys like Will Tillery and the others.
Old May 5, 2011 | 11:32 PM
  #23
badicedog's Avatar
Scored on two used SAI manifolds! On to the next problem... I've removed the upper intake manifold, front AC/ PS brackets, Fan and cooling lines/hoses to Intake manifold. I don't see the disconnect to the fuel rails... Any suggestions?
Old May 6, 2011 | 06:38 AM
  #24
Bundu's Avatar
Banned
At the firewall end, the 2 rails come together with a single pipe - you can't miss it. Find the disconnect and press the tab on it, but not too hard otherwise it sticks.
Old May 6, 2011 | 10:35 PM
  #25
badicedog's Avatar
I was reading "Engine refresh" by Paulp38A.com, he recommended replacing the tappets while doing the HG job and using the silver Payen valley gasket instead of the black composite. Any ideals on this? I'd rather do the job right and only once.
Old May 6, 2011 | 11:19 PM
  #26
jafir's Avatar
I wouldn't put lifters in an engine without replace the cam too.
Old May 7, 2011 | 05:10 AM
  #27
Bundu's Avatar
Banned
X2: lifters and cam go together. You don't want to be replacing a cam as well, unless you have worn lobes.
Old May 7, 2011 | 06:39 AM
  #28
vandev's Avatar
Default yep
X3 on Bundu....cam, tappets, push rods all go together... the gasket Kit from AB is fine.... The best would be Cometic but there $100.00 per side... If you want you could do ARP studs...I am doing my daughters 2000 DII now and i got studs.... I understand the science behind it but we will see.... Doing on my 2004 also but thats a full rebuild...
Old May 7, 2011 | 06:59 PM
  #29
kcabpilot's Avatar
That reminds me of another great tip that I read about but it was too late for me to use:
Cut the heads off of four of the old head bolts and thread them into the block to use as guides when reinstalling the heads.
Old May 7, 2011 | 08:55 PM
  #30
badicedog's Avatar
That's a great tip!!! Much appreciated. I was starting to think That I bit more than I can chew!!!
