D2 Internal Roof Insulation
Old Nov 10, 2017 | 04:58 AM
OffroadFrance's Avatar
Default D2 Internal Roof Insulation
If you remove your headliner to seal leaks etc, try fitting this type of insulation which reduces the heat impact inside your D2.
https://www.bricodepot.fr/saintes-sa...ts-/prod38315/
Be careful when you install this insulation that you don't create any short circuits with interior lights etc.
Old Nov 10, 2017 | 08:40 AM
dgi 07's Avatar
Originally Posted by OffroadFrance
....which reduces the heat impact inside your D2.
Heat and Noise.
As someone that rode around with no headliner for close to a year, you'll be amazed at how much wind noise comes through the roof.
If you really want to keep the interior from heating up during the summer months, liner your floors with it too, then reinstall the carpet..
Old Nov 10, 2017 | 11:01 AM
scsand's Avatar
I've got to do this on both of my D2's. Readily available is flooring underlay which states it's for sound proofing and thermal insulation. Not as thick probably but may do the job.
https://www.homedepot.com/p/TrafficM...9554/203956767
thinking about using it..
Jason Andrew
Nov 19, 2012 01:49 PM
DiscoIIBrandon
May 20, 2011 04:55 AM
Jay5oh
Mar 19, 2010 03:26 PM
jdelp
Apr 22, 2008 12:20 PM
chrisusvi
Sep 22, 2007 07:37 PM
