M & S blinking
Old Sep 24, 2022 | 01:55 PM
Wesc233's Avatar
8th Gear
Default M & S blinking
My 2005 D2 M&S blinking on the dash! Seems to be in limp mode. What could be causing this?
Old Sep 24, 2022 | 05:18 PM
mln01's Avatar
I presume "2005" is a typo, since there are no '05 DIIs and in your other posts you say you have an '04.
The flashing M&S lights and limp mode are indicators of a transmission fault. Very often that's caused by an electrical problem. The transmission ECU is VERY fickle and sensitive to low voltage. First, check, clean and tighten the battery terminals, and let us know whether or not that cures the fault. If not, we'll go on to checking and cleaning ground connections.
Old Sep 24, 2022 | 07:23 PM
Wesc233's Avatar
8th Gear
Thanks for the response. I’ll check that on Monday and let you know
Old Sep 24, 2022 | 10:20 PM
acg's Avatar
acg
I encountered this problem a couple of years ago. It was the factory wedge-style terminals. They are prone to coming loose, especially if you hit the gravel often. I used some copper shims on the battery posts. Ideally, I would like to replace the factory battery clamps when I have more time later in the year.
Old Sep 26, 2022 | 11:58 AM
Brandon318's Avatar
Whenever this has happened to me on any Disco, it's because the battery needed a charge. Get yourself a trickle charger and check it/top it off every few months.
https://amzn.to/3ReVSd2
woodchip2bert
Dec 23, 2020 08:57 AM
RawFaith
Sep 15, 2016 02:03 PM
Chrisinhouston
Jun 28, 2012 05:37 AM
yarddawg
Dec 10, 2007 05:19 PM
